I've done a lot of printing in Vase mode before and haven't run into issues, but suddenly am having gaps between layers.
I suspect it has something to do with the large layer heights combined with the curvature, but it really seems like there shouldn't be an issue. It only happens in the curvy areas. When I lower layer heights down to 0.25 or less the gaps begin to disappear. However I am trying to print clear with T-glase so I'm printing between 0.4 and 0.8 layer heights with a 1.0mm nozzle. Is there some obvious setting I'm missing to fix this issue? I can get rid of the gaps by not using Vase mode, but I really need to use vase mode as the seam with the larger nozzles is really distracting.
