Hi all,
i'm new with S3D and I didn't find a solution to my problem, in posts o tutorials...
The point is: does any one of you tried the dual extrusion print using Bad Printer 2 (a marlin modified firmware)?
while I've setted the offset for T1 in the Gcode Tab and the preview works fine, in the printing process the offset is completely ignored and the two part (processes configured following tutorials) are printed in two differet positions not mixed as it should be.
Not found other place where to set this parameter.
may anyoune tell me how to fix this behaviour?
Thanks a lot
