The object is 15mm tall; each of the three sections are 5mm high. I used 0.4mm layers for the entire print except on the top surface of each section where I used a single 0.2mm layer. Each 5mm section should be made up of twelve 0.4mm layers (totaling 4.8mm) and one 0.2mm layer, and that's the way I created my processes. However, as you can see from the screen shot in "preview mode," the first and third sections look as expected, but the second section does not. The most obvious problem: there's a gap where the first and second sections are supposed to meet. If you look closely, the 0.4mm layers appear to be shifted up and smashed into the top 0.2mm surface of that section. Is this a rendering glitch? A bug in the g-code?
https://dl.dropboxusercontent.com/u/600679/Test.factory
