On almost every print, the printer pauses, and if I'm not present to hit the Force Next button in the control panel, the heat from the extruder tip deforms the geometry of the part. I've searched the internet for this issue, and it seems it's a problem for Windows 10 operating systems. I've tried the suggestions to remedy the problem, with no success.
It seems the software can detect the problem, for under the communication tab a warning is issued, "WARNING: Firmware unresponsive" I would like to see a checkbox, either in options or the machine control panel, that will allow the software to perform an automatic force next, should a situation arise where I'm not present to perform this task manually.
3D printer: Printrbot Simple Metal
Controller: Printrboard, rev F
OS: Windows 10 (x64)
