When the building surface is preprinttreated with BluePaintersTape, PVA glue, Elmers GlueStick, Wolfbite, ABS Juice etc the printed object may damage buildingsurface footprint. Saving the building surface footprint including Brim and priming pillar = 1:st layer.
When automatic placing object on the building surface used buildigsurface footprints are avoided.
When manually placing objects on used buildigsurface footprints you get a warning with override.
By remember used buildigsurface footprints one buildigsurface treatment can be used for many prints.
Then a new buildigsurface get new treatment there is a option to reset the saved buildigsurface footprints .
The "Save buildigsurface footprints" is an option. With the option unchecked buildigsurface footprints are not achived = function as now.
