Why is there only a place to make settings to the FIRST layer and not the Last Layer(s)? (or is there?)
Having a place under the "Layers" tab to also make adjustments to the LAST layer would be a good idea.
Seems the last layer is very important because if there were settings for the LAST layer you could, for example, slow down the print speed, increase the flowrate, change the temperature ect to help produce a better appearance on the last layer. No?
There may be a good reason for not having last layer adjustment settings and I'm just not advanced enough yet to realize why.
