I have a flashforge creator pro and I am trying to print from my laptop instead of using a disk on the control panel. When I go to print using the USB connection I get an error messages that says; I need to set the correct Port and Baud rate. What is that and and how do I do that?
You need to make sure you have the FFCP serial drivers installed. Any yes, also pick what port the printer is connected on (usually it's COM-something). I believe the baud rate should be 115200.
