horst.w wrote:I know, it is a real problem and I don't know why S3D doesn't declarate the outer perimeters so as they do it with the inner perimeters.
But the real speed is counting and my example with 135 mm/s (theoretical) shows that the speed is reduced to an agreeable value, so that we can say: it works.
agree I havent really bump up my overall speed as your test might as well give it a go
I believe also there is a bug, but what we can do?
not much but report
The first filament for a bridge is the basement for all that will follow. The extruding filament out of the nozzle must be stick nearby so that it binds the two towers together with a strait on horizontal line.
To reach this, I think that
- the cooling must be running
- the extrusion must be reduced
- the speed must be reduced too.
to allow the plastique to cool down as fast as possible.
- I have 3 fan, 1 for heatshink 2 for active coolling and 1 desk fan blowing to the printer
- if I reduce my overall extrusion multiplier in the extruder tabs I will be getting under extrusion for my print, there is no option to reduce multiplier for those external perimeter when bridging
- did slow down it to 20 mm/s but my printer is overstruding plastic for outer perimeters, bridging are as ok as I can reduce the extrusion multiplier
The measure for this is to be find out and depending from material (PLA or ABS e.g.), distance between the towers and all other parameters of the print.
And it ist necessary that the nozzle does not lose the contact to the towers when bridging is starting. It needs a solid overlap of them.
My mendemax can only print PLA, for ABS I have a flashforge dreamer which is work great but I still need to print PLA with large build platform
Your first picture shows a hanging perimeter. I would say, in this case the quantity of extruded filament was to high and it hasn't cooled down enough relative to the movement of the print-head. It is a very small window for all responsible parameters to build a well done bridging. The amount of all is everytime 1.
agree the amount of plastic extruded always used the multiplier set on the main extruder
The best of all strait on horizontal standing filaments I have produced by my own failure: I had forgotten to switch on the retract and when the print was finished and the toolhead was going with travelspeed to X-Home, it pulls out a filament as strait as a filament can be.
So it may be perhaps helpfull for certain materials and conditions to boost the speed.
H.
wont S3D will increase the extrusion when we bump up the speed even more in order to keep up with the extrusion multiplier? that what I having right now to much plastic extruded regardless of speed I set for outer perimeter while bridiging
