1st off .. Hi all .. i'm new to the 3d printing world.
i'd been following the technology for a long time and its now withing the reach of normal users to experiment with ..
so last week .. i bought myself a CTC dual extruder printer. vendors description CTC Bizer Dual Extruder Desktop 3d Printer, Mk8
out of the box it was 'fun' . nothing would stick to the bed .. in the end i solved that.
heated bed temps seem to report wrong , being approx 30-40c to low .. seems a common issue on this printer.
i have it all working .. 1st on the right hand extruder.. then after much adjusting and stripping the extruders and steppers down a few times i now have it printing from the left also. i have both the hot end heights just right (that was fun !)
my problems that i have been unable to solve start here
filament does not flow as quick on start up as it should . not an issue on single color as once it does a raft the flow is ok.
on dual color when it changed from one to the other it then leaves gaps or does not work at all .
i also need to calibrate the 2 extruders but because of the change of color it makes printing the calibration thing in repg a problem.
does anyone have one of these printers who could give some advise
