I often find myself going through a process of changing the orientation of a model to reduce print time. I was reading this great article about that problem that Matthew Mead wrote: http://matthewtmead.com/blog/print-mode ... derations/
it got me thinking, wouldn't be great if I could select a model then click a button and after rendering all for orinations S3D could generate a print time chart, I would think that the process would have to have a dialogue box to be able to set some key features by orination or maybe each process would have to be worked out in advance.
the way I work today is that I move quick for each orientation to get a rough idea of time, then pick my direction then cutomize from there. so for me a table with time would be a great shortcut but ideally I would see all 4 views of the models with supports but that is maybe on the fancy side.
thanks
Sami
