JJ Viernes
cannot print using simplify 3d
my printer is Da Vinci 1.0A, but still i cannot print using simplify 3d, after submitting the job. it just stop. and nothing will happen,
Any tips and advice please.
Re: cannot print using simplify 3d
Are you using the stock S3D profile for the da Vinci 1.0? It works fine for me.
Perhaps you can attach the .3w file you created with Simplify3D so someone else can test on their printer.
JoshuaYates
Are you sure your printer is connected correctly?
Are you able to control your printer using the machine controller built into the software?
BaudR8
in the scripts tab, in post processing on a new line after the prepend command try adding:
{REPLACE "\n" "\r\n"}
see if that helps
