JoshuaYates
External Edges
Hello,
I would like a feature adding where I can set the infill speed as 1 setting, the inset (first Shell) as another speed and the final outer shell as another.
Makerware has this feature in there custom profiles and it very helpful and would really like this adding into this software.
It means I can infill at speeds like 90mm/s and external finishes as 30mm/s.
At the moment, its trying to do the shells way to fast at 90mm/s even with a 20 % outer layer speed as the first infill is much quicker then the outer shell.
Also it might be nice to put mm/s for the outline under speed in stead of a percentage.
