I find that I can specify different angles for support structures to print under the SUPPORTS tab. So I set two angles, 0 degrees and 90 degrees.
But can I specify the angle for certain support sections of the print and not others? (Not by layer but by X,Y coordinates)
How would I tell the software specifically what angle to print supports under different sections of my object?
Would this have to be a direct G-Code edit?
