I'm getting familiar with the interface and overall, very happy with how the work flow is with S3d. That's the good news, but I'm also having a problem that's totally mystifying to me. I can print a 20mm cube that's as perfect as you'd want and I've created a 1x4" cylinder that prints perfectly - see my photo. But next to the cylinder you will also see two items that were not as intended.
These were elements in a lcd frame that I downloaded from thingiverse. Two different designers, two different designs, but in both there is a certain amount of printing that is according to design, then there is a steady slide in both the x and y axis. I do not believe there is any mechanical problem with the printer as it printed the forms I designed perfectly.
I'm currently reprinting one of the items I sliced with slicer3d and printing with Ponterface and so far, it's printing perfectly.
Any ideas???
Thanks,
Larry
