I thought I would throw this up here to see if anyone has had the same issue. I have been using Simply3D for about 2 weeks now to print on my Rostock V2 without issue. That is, until now.
All of a sudden I get this strange occurrence where when I first connect to the printer and click "Print from USB" S3D sends a few initial commands to the Rostock (i.e. towers home) and then nothing. The stream of replies in the Machine Communication window just stops and even after stopping the print I get nothing.
In order to print using S3D I have to select "Disconnect" and then "Connect" in S3D. After that, it works fine...at least until the next print.
Anyone else have this issue? Any thoughts? I already uninstalled S3D and totally cleared the Process settings.
I am using a Windows 7 64-bit laptop.
