Surprisingly, I couldn't find anyone talking about the finer points of printing threads.
Here's the problem. No threads on the printed model.
I have an OpenSCAD generated STL with two parts that connect with generated threads. Slic3r had no problem slicing this at 0.2mm and I got a beautiful print from it (below). Slicing the same file with S3D, no matter what settings I tried, produced either really bad threads or none at all (the higher the resolution of the STL, the fewer threads printed).
S3D on the left, Slic3r on the right, mostly identical settings (except for concentric fill on the left, and ignore the missing column on the right, I broke it):
There's other fit and finish issues with the left print. It's shiny and it lacks a nicely finished top layer. Every print I've done in S3D has a poorly finished top layer.
I tried enabling support and found S3D trying to build random supports for the threads. I suspect there's an overhang settings I haven't found that might help.
Green part (no threads printed)
OpenSCAD: https://dl.dropboxusercontent.com/u/331 ... older.scad ('res' was 360 for the green part)
Original: https://dl.dropboxusercontent.com/u/331 ... d/test.stl
Netfabbed: https://dl.dropboxusercontent.com/u/331 ... _fixed.stl
Purple part (many short threaded segments printed)
OpenSCAD: https://dl.dropboxusercontent.com/u/331 ... older.scad ('res' was 30 for the purple part)
Slic3r: https://dl.dropboxusercontent.com/u/3311552/s3d/top.stl
S3D: https://dl.dropboxusercontent.com/u/331 ... d/top2.stl
S3D settings
0.2 NORMAL from Josef Prusa: http://shop.prusa3d.com/forum/download/file.php?id=533
Factory: https://dl.dropboxusercontent.com/u/331 ... ds.factory
