My nozzle diameter is .4mm....but simplify 3d wont generate any print preview using these settings on a .4mm single wall tube...unless I use some horizontal size compensation.
Why would it not generate output with a .4mm nozzle diameter (extrusion width @.4mm) and a .4mm wall thickness?
I would think that is within the tolerance.....I can see trying to print a .25 wall thickness with a .4mm nozzle being an issue...but I would think this would work
