Robb
Dual extrusion question
Quick question i can't seem to find the answer to.
If you have one STL file can you tell simplify to switch to a different extruder at a certain layer or hight? Or do i need to cut the file with Netfab and reload both STL files?
Re: Dual extrusion question
Sure, you just use the start/stop printing at height options on the Advanced tab. You can actually change any setting you want for different sections of the print (not just the extruder that is used).
See this link for more info: https://www.simplify3d.com/support/tuto ... f-a-model/
