I'm learning a lot about 3d printers having just gotten my first one: a Taz 5.
I was using Cura initially, but after reading the reviews for Simplify3d I figured I would make the purchase early on so I could use it throughout the learning process instead of switching down the road.
I'm very happy with Simplify 3d, but Cura did one thing that Simplify3d is not. When you started a print with a Cura G-Code the Extruder went to the corner of the bed, lowered and extruded a little, picked up off the bed, lowered again, and then started the printing process. I never had a problem with extra filament being dragged into the print.
Simplify3d goes to the corner of the bed, lowers, and then goes to print. It drags some oozed out filament into the print causing all kinds of trouble. My searches indicate I need to create a startup script.
I looked at my Cura Gcode and it has:
Code: Select all
;Sliced at: Wed 30-12-2015 21:09:05
;Basic settings: Layer height: 0.1 Walls: 1 Fill: 20
;Print time: 1 hour 6 minutes
;Filament used: 1.128m 3.0g
;Filament cost: None
;M190 S0 ;Uncomment to add your own bed temperature line
;M109 S0 ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F10500;move the platform down 15mm
G92 E0 ; zero the extruded length
G1 F200 E0 ; extrude 3mm of feed stock
G92 E0 ; zero the extruded length again
G1 F10500 ; set travel speed
M203 X192 Y208 Z3 ; speed limits
M117 Printing... ; send message to LCDCode: Select all
G28 ; home all axesThere is a lot of stuff going on in the Cura startup script and I am tempted to just copy paste it into the startup script area of Simplify 3d, but I am afraid I might add something to it that will mess Simplify3d up. I'm not really sure what absolute positioning would do and it seems those speed limits would slow me down. Also if I start with the fan off, will it still come on later?
I'm guessing I would modify it into:
Code: Select all
G92 E0 ; zero the extruded length againThank you for taking a look!
-Mike
