Should I add a raft and print it vertically?
It didn't do so well horizontally.
The problem with printing it vertically is it will break much easier than if it had printed horizontally
Agreed. Just out of curiosity I went ahead and printed the rod and also a block that had been created with inside thread matching the thread on the rod by subtracting the threaded part of the rod from the block. Surprisingly, the threads on both printed accurately and better yet they worked!dkightley wrote:The one problem with printing your threaded rod is actually the thread!. The quality and completeness of the printing of the thread this way is dependant on the nozzle width and the pitch of the thread. A 0.2mm nozzle and a very coarse thread might print okay.....but a file thread would fail on wall thickness.
I have successfully printed long thin cylinders lying down.....the upright tubes in the second photo down in this thread on TalkingTGauge: http://www.talkingtgauge.net/viewtopic.php?f=8&t=123 The important thing is that there was no features that would fail due to thin walls.
Good idea. Not sure what I was thinking to make the threads so small.billyd wrote:I find if you want to use threads in your printed designs it's best to make up your own, extremely course ones rather than standard real machine threads. This is because small details really cause problems. So for example instead of drawing a 3/8-16 unc thread, I would make up one like a 3/8-4 thread. It still will thread, but it will be much easier to print and likely a lot stronger.
