Log as requested . . .
Attempting connection at ...
Error connecting to port.
Attempting connection at COM3...
RECEIVED: start
Connected to machine!
SENT: G21
RECEIVED: echo: External Reset
RECEIVED: Marlin: 1.0.0 RC2 for MakerGear M2
RECEIVED: echo: Last Updated: 2012-05-30 | Author: johnny
RECEIVED: echo: Free Memory: 4775 PlannerBufferBytes: 1232
RECEIVED: echo:Using Default settings:
RECEIVED: echo:Steps per unit:
Steps per unit:
RECEIVED: echo: M92 X88.88 Y88.88 Z400.00 E471.50
RECEIVED: echo:Maximum feedrates (mm/s):
RECEIVED: echo: M203 X500.00 Y500.00 Z250.00 E200000.00
RECEIVED: echo:Maximum Acceleration (mm/s2):
RECEIVED: echo: M201 X9000 Y9000 Z30 E10000
RECEIVED: echo:Acceleration: S=acceleration, T=retract acceleration
RECEIVED: echo: M204 S3000.00 T3000.00
RECEIVED: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s)
RECEIVED: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
RECEIVED: echo:PID settings:
PID settings:
RECEIVED: echo: M301 P7.00 I0.10 D12.00
RECEIVED: echo:SD card ok
SD card ok
RECEIVED: ok
SENT: M140 T# S60
RECEIVED: ok
SENT: M104 T# S185
RECEIVED: ok
SENT: M105 T#
RECEIVED: ok T:36.5 /185.0 B:21.2 /60.0 @:127
SENT: M105 T#
RECEIVED: ok T:40.1 /185.0 B:21.2 /60.0 @:127
SENT: M105 T#
RECEIVED: ok T:44.1 /185.0 B:21.2 /60.0 @:127
SENT: M105 T#
RECEIVED: ok T:47.6 /185.0 B:21.3 /60.0 @:127
SENT: M105 T#
RECEIVED: ok T:51.7 /185.0 B:21.5 /60.0 @:127
SENT: M105 T#
RECEIVED: ok T:55.7 /185.0 B:21.4 /60.0 @:127
SENT: M105 T#
RECEIVED: ok T:185.0 /185.0 B:60.2 /60.0 @:19
SENT: M105 T#
RECEIVED: ok T:184.8 /185.0 B:60.2 /60.0 @:20
SENT: M105 T#
RECEIVED: ok T:184.9 /185.0 B:60.2 /60.0 @:19
SENT: M105 T#
RECEIVED: ok T:184.7 /185.0 B:60.2 /60.0 @:21
SENT: M105 T#
RECEIVED: ok T:184.9 /185.0 B:60.3 /60.0 @:19
SENT: M105 T#
RECEIVED: ok T:184.7 /185.0 B:60.4 /60.0 @:20
SENT: M105 T#
RECEIVED: ok T:185.0 /185.0 B:60.4 /60.0 @:19
SENT: M105 T#
RECEIVED: ok T:184.8 /185.0 B:60.4 /60.0 @:20
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
RECEIVED: ok T:185.0 /185.0 B:60.5 /60.0 @:19
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
RECEIVED: ok T:184.9 /185.0 B:60.4 /60.0 @:19
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
RECEIVED: ok T:184.8 /185.0 B:60.3 /60.0 @:20
SENT: M105 T#
RECEIVED: ok T:185.0 /185.0 B:60.3 /60.0 @:19
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
RECEIVED: ok T:184.9 /185.0 B:60.2 /60.0 @:20
SENT:
G-code file never started, so after hitting "Stop" following 8 minutes of inactivity:
SENT: M105 T#
SENT:
Total build time: 6.07 minutes
SENT: M105 T#
RECEIVED: ok T:185.3 /185.0 B:60.2 /60.0 @:18
SENT: M105 T#
RECEIVED: ok T:185.4 /185.0 B:60.2 /60.0 @:18
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
RECEIVED: ok T:185.4 /185.0 B:60.1 /60.0 @:18
SENT: M105 T#
SENT: M105 T#
RECEIVED: ok T:185.4 /185.0 B:60.0 /60.0 @:18
SENT: M105 T#
SENT: M105 T#
SENT: M105 T#
RECEIVED: ok T:185.3 /185.0 B:60.0 /60.0 @:18
SENT: M112
RECEIVED: ok
Disconnected.
Emergency stop issued! Attempting to reconnect...
RECEIVED: start
SENT: G21
Steps per unit:
SENT: M105 T#
PID settings:
SD card ok
RECEIVED: ok
RECEIVED: ok T:185.4 /0.0 B:60.0 /0.0 @:0
SENT: M105 T#
RECEIVED: ok T:185.1 /0.0 B:59.9 /0.0 @:0
