Heartlander
Extrude, X & Y stopped working
Solidoodle 3 printer. I just started using the Bed Leveling Wizard. The filament got caught under the printer cover and kept the print head from going quite to the farthest point. It made the grunting noise and I immediately shot off the printer.
Now, in the Control Panel, I am Jogging the extruder and XY but they don't respond. Likewise, in the Bed Leveling Wizard, I click Begin (it Homes) then Next and nothing happens.
I have restarted printer, PC, Simplicity3D, still no cigar. I thought at first it was the setting to "Wait until temp stabilizes" but I unchecked that and it still won't go.
Any ideas?
Re: Extrude, X & Y stopped working
Well I would turn everything off and then back on. You may also want to check all of the wiring on the printer to make sure nothing got accidentally unplugged.
Heartlander
After setting overnight, it is working again. Thanks, Carl. Are you the same Carl on the Soliforum?
Heartlander
And now its not working again.
