Can anyone tell me what Z home offset does Simplify3D assume exists from levelling the bed?
I'm using a PrintInZ Zebra print bed. They recommend setting a 0.2mm clearance between the nozzle and bed when levelling as the bed is damaged by contact with the hot nozzle. However, my prints never came close to sticking on the bed. By progressively adjusting my Z home offset, I gotten successful prints, but the nozzle was just touching the bed and left a mark.
From this it would appear that Simplfy3D assumes zero clearance between the nozzle and bed at the Z axis home position.
I have been able to work around this by setting a 0.2mm nozzle-bed clearance and a Global G-Code Z-Axis Offset of -0.2mm. The problem is that the G-Code previewer now shows the print as starting 1 or 2 layers below the print bed. Would I be better off setting the Origin Offset for the machine definition?
