I recently purchased Simplify 3D specifically for the easily removable support material.
Unfortunately, Simplify 3D is not as simple as I thought to setup, and I've found no guides to setting up the Robo R1 Plus.
Does anyone have any profiles, presets, or configuration files I would be able to use?
I found a FFF process file for the Robo R1, and attempted to use it; It came out quite poorly, with the support material penetrating the deformed object.
I've tried adjusting many settings, and I'm quite confused on what to do.
I'd really appreciate any tips, advice, or settings I could get.
Below is the image of the failed print, using ABS, with a raft and support material. The object was intended to be a sphere, in which I could break away from the support material.
