I would like a better system for managing materials.
For example:
PLA
Hatchbox Blue PLA
Hatchbox Red PLA
Nylon
T-Glaze
T-Glaze Clear
etc.
The reason being I want to manage a lot of customized settings based on how I've seen a material work in the printer. I've had PLA of one color need a higher temperature for a good extrusion than PLA of a different color. I'd rather not have to re-enter and maintain all of the settings, I'd like to see it inherit from the parent and show (by color maybe) the settings that are inherited vs the colors that are overridden.
It would also be nice to be able to manage printed filament counts. For example, you tell the system when you load a new spool (or give each spool an inventory number so you can have multiple spools of the same material at different levels of use), and then automatically decrement the used amount for a print (or for an export, since I print using OctoPrint), and warn if you may run out of filament during a print.
