groundfeel
Simplify3d to cubepro file
So i got this problem the machine wont recognize the 3th jet and is asking me just for the 2 how can i do a correct export to cubepro file
File error
File error
Re: Simplify3d to cubepro file
It's probably something in your starting script. That's where most of the commands are that determine how the nozzles are setup and what material you are using in each one.
bloomlab
yes please can you send me the scripting codes to select the material color and jets and every other code needed please i would like the full list
this is for a cubepro trio
groundfeel
Hello, I need the full list of codes, especially the ones related to color, material and jets please this is very important, we are at the DARLAB at London South Bank University and we can not go further in our project due the lack of support from your side...
First of all, the commands for the BFB-style printers are VERY poorly documented. The manufacturer (3D Systems) never bothered to completely document what commands are used to run the printer. So I doubt you're going to find an all-inclusive reference. There's a few links that you can easily find with google that have SOME of the commands, but plenty are missing. It's just the unfortunate truth of buying that printer.
Second, this is a user forum. So it's all just other users here who are offering to help out. So be nice, and perhaps someone else here has gone through the same issue and can help!
groundfeel
Yes thanks I get you I'm confused I thought this is the support for the software so I'll have a talk to cube pro thanks
groundfeel
cubepro wont share this info they just said
by the way do you have the code for washable material?
and does -1 means none selected jet?
and ^MaterialCodeE3:260 this is the code for pla?
and what is the code to select the main extruder?
groundfeel
do you have colors and materials codes?
BaudR8
You can use the cubepro software to slice a simple object and then get the color codes/material codes you want by decoding the cubepro file using Codex Utility
groundfeel
it will generate the bfb then what do i do?
how can i see the codes?
