Bakkeskaug
Does not create support structure
Hi
I have a problem when trying to slice an object in Simplify3d versjon 3.0.2. The program does not generate support structue for my object.
Support structure selected OK
Support selected to primary tool
Support angle ties 45, 60, 65, 20 degrees
Support from build table and normal setting tried but same result
It works to add support structures manually but not generating automatically
what to do?
Re: Does not create support structure
I don't think anyone is going to be able to help you unless you post your factory file (File > Save Factory File)
