HotPockets
Newbie Question: Flashforge Creator Pro Temp Question
Hello,
I have a FlashForge Creator Pro and it is running the Sailfish Firmware.
I use Simplify and have it set the temperature for the extruder I am using (Left) and the heated bed and save it to a file for use on the SD Card.
When I run the file on the printer it sets the Bed to the correct temperature (110 C) but it tries to set the extruder to (0 C). If I select to manually override from the LCD Panel, it will set to the temperature I set it to (225 C). I checked the model file and it has the following line so I am assuming it is formatted correctly
; temperatureName,Right Extruder,Left Extruder,Heated Build Platform
; temperatureNumber,0,1,0
; temperatureSetpointCount,1,1,1
; temperatureSetpointLayers,1,1,1
; temperatureSetpointTemperatures,0,220,110
; temperatureStabilizeAtStartup,0,0,0
; temperatureHeatedBed,0,0,1
; temperatureRelayBetweenLayers,0,0,0
; temperatureRelayBetweenLoops,0,0,0
; fanLayers,1
; startingGcode,; **** Replicator 1 dual start.gcode ****,M73 P0 ; enable build progress,G162 X Y F3000 ; home XY maximum,G161 Z F1200 ; home Z minimum,G92 Z-5 ; set Z to -5,G1 Z0 ; move Z to 0,G161 Z F100 ; home Z slowly,M132 X Y Z A B ; recall home offsets,M135 T0 ; load right extruder offsets,G1 X150 Y-70 Z30 F9000 ; move to wait position right hand side of the table,G130 X20 Y20 Z20 A20 B20 ; lower stepper Vrefs while heating,M126 S[fan_speed_pwm],M140 S[bed0_temperature] T0,M134 T0 ; stabilize bed temperature,M104 S[extruder1_temperature] T1,M133 T1 ; stabilize left extruder temperature,G130 X127 Y127 Z40 A127 B127 ; default stepper Vrefs,G92 A0 B0 ; zero extruders,G1 Z0.4 ; position nozzle,M135 T1 ; left tool,G1 X110 Y-70 E30 F300 ; move nozzle,G1 X120 Y-70 Z0.15 F1200 ; slow wipe,G1 X110 Y-70 Z0.5 F1200 ; lift,G92 A0 B0 ; zero extruders,M73 P1 ;@body (notify GPX body has started),; **** end of start.gcode ****
Re: Newbie Question: Flashforge Creator Pro Temp Question
Are you using the stock FlashForge Creator Pro profile from the S3D configuration assistant? I use that profile all the time, and I haven't had any temperature issues. So you might want to try re-downloading it (just go back to the config assistant and select it again).
Also, keep in mind that if you are printing with the left extruder, the right extruder will probably be set to zero (i.e. turned off) during the print, even though the left one is heating up ;)
