This behavior is odd and inconsistent. Sometimes it saves as .g3drem and sometimes .gcode . If I try to send a .gcode file to the printer I get the error message "This printer does not support plain text gcode files"CompoundCarl wrote:Their stock profile saves as .g3drem. I'm using it right now. If you modified their stock profile, it's possible you changed that, so that's why I recommended re-downloading it.
One other thing to note - when you click "Save Toolpaths to Disk", it may prompt you with a name that ends in .gcode, but it will get automatically converted to a .g3drem when you actually save it. This is the same with many other file formats too. Some even export both the .gcode file along with the final file format so that you can keep both for reference (this is mostly used for binary files, since the final binary file is pretty much unreadable).
