I wish to heat the bed to temperature before heating the extruder. I tried adding the commands in the start up script but when I look at the code there is already lines above the start up script which heat the extruder first and then the bed, which is what I do not want to happen. Is there anyway of moving the start up script further up or deleting the lines above it.
G90
M82
M106 S255
M140 S60
M104 S230 T0
M109 S230 T0
G28 ; home all axes
M190 S60
M109 S230
G1 E-1.0000 F1800
G1 Z0.250 F1002
The 3 lines of code in between the asterix are the start up script and I would like this to go under the G82 command.
Any help would be appreciated.
