I have a Flashforge Creator pro and it has MK10 0.4mm nozzles , I ordered the wrong nozzle , I ordered MK10 0.6mm nozzle, if I put this on my printer is there any adjustments in the software to change nozzle size or is there settings I should adjust, Please help, Thanks, Kevin
Go to the Extruders tab and change all of the extrusion width values to automatic. Then enter 0.6mm for the nozzle diameter. Now the software will automatically choose the best settings for your larger nozzle.
Note: if you have multiple extruders on the Extruders tab, make sure you click on each one and make the settings changes for all of them
