Hello,
I just bought S3D after much frustration using makerware and I have to say that so far I am very pleased. I am however having one issue.
I work with dual extrusion prints quite frequently and in a few of my designs I have features on the model that are recessed from the roof. The problem with this is that when quick printing using low infill %'s, there often isn't internal support for these recessed features. So one way I have discovered of possibly combating this is to use multiple processes.
Up until the recessed feature prints, I would like to print at a low infill. So I turn off the roof layers, keep the infill low and move on. Then right before the feature, I create a process with 0 top and bottom layers and rafting turned off. I then select an infill of 50% for several layers using the 'start print' and 'stop print' options in the advanced dialog. I then create a third process with 0 bottom layers and 3 top layers, rafting off, and 15% infill to finish out the print.
The problem I am having is that the first process works according to the preview, but then with the second and third processes, it only prints using T0 (right extruder) and ignores any future dual extrusion commands.
Is there a way to create multiple dual extrusion process groups so dual extrusions will continue to print seamlessly? Is there something I am missing? Can it not be done as of now?
