It would be nice if you can select / remove supports that are connected
I very often have the case that i want to remove a 'set' of supports that are all in the same region / connected, and have to click them one by one
Also if grouping is implemented, it would be possible to give different types of support to different sets / regions (e.g. rotate the support 90°)
