erniehatt
Print problem
I have finally got my printer up and running again, but as expected with the first print I have problems
The skirt prints fine, but as soon as ir starts to print the model it all seems to shift to one side and overlaps the skirt, also after a short while it is going backwards and forward over the same spot, anyone able to tell me what is wrong. Thanks :? :? :?
erniehatt
Re: Print problem
No matter I have solved the problem.
Re: Print problem
It would be really nice if you could advise how you resolved this issue. It may help others who have the same symptoms...
erniehatt
Re: Print problem
Ok, it was caused by another bad fitting piece of printed part that came with this very bad printer kit bought off ebay by sintron, I have had to just about replaced every part, even the motor blew up.
What was happening this time was the X axis rod were a bad fit and were moving and making the belt loosen, a dab of glue on the ends cured it.
