qarbiq
Ultimaker 2 Underextrusion
I am new to this. Can anyone help me with this ?
I am trying to slice my model using simplify3D and use it for my ultimaker 2. I use the predefined settings for ultimaker, but when I try to print , it is under extruding right from beginning . I notice the feeder gear is rotating so slowly . Why is that ? What setting should I change ? Shouldn't the pre-defined setting already have that there ?
Thanks for all help
Re: Ultimaker 2 Underextrusion
The speed of the extruder motor can change for a lot of reasons. For example, if you're printing very slowly on the first layer. So I wouldn't be too alarmed by that.
Do the prints actually come out looking under-extruded?
PS - there's a great guide covering what to check for this issue here: https://www.simplify3d.com/support/prin ... gh-plastic
