Thehead
Bed level before extruder heats up
I was trying to find a way to bed level before the extruder heats up, it seams that the heating of both the bed and extruder happen automatically as opposed to being in the g-code. This is so my extruder doesn't melt through my buildtak.
Re: Bed level before extruder heats up
If you want to customize where the preheating happens, you just have to use the [extruder0_temperature] variable in your starting script. For example
G28
M109 S[extruder0_temperature]
That will home then nozzle, and THEN preheat the extruder.
You can read more about this here: viewtopic.php?f=8&t=1959
Thehead
Thanks! I'll give that a try.
