NoHands
Object disappears when prepare to print
Hi Everyone
sometimes when I load a object into simplify3d they look fine but when I prepare to print it disappears or partially disappears
any ideas?
thx
i'm a quadriplegic on life support with no movement but my chin
Check out my website www.higherthansuperman.com
Re: Object disappears when prepare to print
Perhaps you can attach a sample factory file so that someone else can try?
NoHands
here are 2 files i have trouble with
thx
tubeclip.stl
(27.33 KiB) Downloaded 386 times
dovetube.stl
(34.46 KiB) Downloaded 372 times
Can you attach the FACTORY FILE? That's much better than just the STLs
Setup everything and then right before you click "Prepare to Print", go to File > Save Factory File.
NoHands
how arecthese?
tubeholder.factory
(4.44 KiB) Downloaded 297 times
dovetube.factory
(9.99 KiB) Downloaded 441 times
NoHands
and the tube holder
tubeholder.factory
(4.44 KiB) Downloaded 330 times
On the Advanced tab, you currently have it set to START printing at 35mm. Your models are much shorter than that, thus there is nothing to print.
Disable the "start printing at height" option and it will slice fine.
NoHands
thanks heaps i feel silly now lol
NoHands
I am still having problems with thiss one tho
dovetube.factory
(10 KiB) Downloaded 396 times
That part is wayy too thin for your nozzle. You can't print a 0.2mm thick wall with a 0.4mm nozzle.
This explains it more: https://www.simplify3d.com/support/prin ... ng-printed
