this plug here, seems fine until the very last layer, i took screenshots to show the issue. its making a D shaped hole on layer 50 out of 50, layer 49 its still printing in a full circle.
49th layer
50th layer (Top layer)
pcman wrote:Please post the factory file. That will make it much easier for someone to identify the problem.
Agreed, and that's not uncommon. But in this case, it glitches even though the model passes all S3D's checks, which I haven't seen happen before.jimc wrote:there was probably a very minor mesh issue that s3d was picking up on.
interesting, didnt know what that tool did to be honest with you. downloaded this thing right off of thingiverse for calibration use too!jimc wrote:yes its your model. your model is a bunch of unconnected surfaces. nothing is joined into a complete solid. prior to slicing your model, if you take the cross section tool and select z axis. move the slider down so you can see inside your model. you can clearly see all the individual surfaces you have.
