Moderate speed, 0.06 layer resolution on an UM2 which works kinda perfectly on Cura
I've attached the problem.
About every print I make has no proper tops.
I've the standard 2 shell layers but they simply do not properly work on top.
This model had infill (13%) which is normally more than enough, it should work with 0% infill as well.
Please give me some hints about the issue.
Material is ABS, temp is 240%, chamber is mostly enclosed, fans were low
