CouldBeACrow
Moving a part on the build plate
So I've moved a part farther to the left than it would normally be. However when I go to print it, the model is printed in the center as if I had never made the change.
Re: Moving a part on the build plate
That probably means your homing offsets are incorrect in the firmware. What printer do you have?
CouldBeACrow
CompoundCarl wrote:That probably means your homing offsets are incorrect in the firmware. What printer do you have?
Flashforge Creator Pro
What firmware did you install on it? You need to change the homing offsets in your firmware
CouldBeACrow
CompoundCarl wrote:What firmware did you install on it? You need to change the homing offsets in your firmware
Sorry, I'm not sure what you mean by firmware... I'm new to 3d printing
What firmware is on your FF Creator Pro? Click around on the LCD panel. Sometimes there is an info screen in the menu that will tell your the firmware version and type.
Did you buy the printer new or used?
