If you look at the attached image you will see that when I import into Simplify a model that has parts that "overlap" each other, Simplify will hollow that part out. I was wondering if anyone had figured out a way to make Simplify see this as one continuous area.
I can get it to work properly by making one clean polysurface with no intersection. That takes a lot of time so I would like to leave the overlap.
https://www.dropbox.com/s/jk26hjzh8qk16 ... p.png?dl=0
