Any news on this? I have the same problem :/
The top fill at spots like these falls down into the infill, even after 5 layers of top fill.
I'd need something like the "extra bridge length" but for top fill.
This is something that also bothers me about S3D - it doesnt seem to take into consideration that each filament of the top infill is not ending on a piece of filament from the support below (since it is sparse) and you essentially get a piece of plastic in mid air that gets dragged back by the head is it moved back.EdoHamburg wrote:Hello!
I have a issue with the software. It is hard to describe, but the pictures will show what I mean.
The failure in Simplify3D - one of the top layers is not going far enough over the infill - the result are gaps/holes:
I Just ran a few tests myself, and the infill overlap setting definitely affects the outer layers as well. So I would disagree with that comment based on my tests.billyd wrote:Including the infill overlap setting.
CompoundCarl wrote:I Just ran a few tests myself, and the infill overlap setting definitely affects the outer layers as well. So I would disagree with that comment based on my tests.billyd wrote:Including the infill overlap setting.
It definitely has an affect. Just look at the gcode preview. If you change the settings from 0% to 50%, it clearly alters the overlap, exactly like you would expect. Even looking through the gcode files itself verifies that it's doing exactly what it should.billyd wrote:Altering overlap had no effect on it, even setting it to 50%
CompoundCarl wrote:It definitely has an affect. Just look at the gcode preview. If you change the settings from 0% to 50%, it clearly alters the overlap, exactly like you would expect. Even looking through the gcode files itself verifies that it's doing exactly what it should.billyd wrote:Altering overlap had no effect on it, even setting it to 50%
