I've spotted something that at first glance looked very odd....but after looking more carefully is something worth documenting.
The First Layer Speed setting adjusts the speed at which the first layer is deposited on the printer build plate. But its not quite as simple as that...
When printing with no raft or skirt/brim, then the setting simply adjusts the speed of the first layer. If you have a skirt or brim, the setting has the same effect...and the skirt/brim will print at the set percentage of normal print speed.
If you print with a raft and disable the raft base layers, then the first layer is also adjusted to a percentage of the normal print speed. However, if you include the raft base layers, then the first layer of the raft prints at a percentage of the raft print speed...which I believe is already 20% of the normal print speed.
This could account for the comments about raft printing speed being painfully slow. If you have a first layer speed set to 50% then the first layer of the raft actually prints at 10% !!
