Printed part speed should be determined by the individual part cross-sectional area, not the overall cross-sectional area of all printed parts.
* if I print one item that is small, each layer will be printed at say 20mm/s as the cross-sectional area is small.... however if I duplicate that part 5 times the software currently thinks that the part is larger (has a large cross-sectional area), so prints each layer at a higher speed!
This is very annoying as small parts need to always be printed slowly... and larger parts can be printed slightly faster... this speed should not be determined by the whole cross-sectional area but the cross-sectional area of each part individually and on an individual basis.
Please fix this. I like Simplify and have been a backer from early on, this still needs correcting.
Cheers,
Lukas
