Have a very strange issue when it comes to printing at the moment.
Currently using S3D on a Flashforge Creator Pro running Windows 10.
Last night set things up to print 4 small parts, placed 1 on bed and duplicated then used center and arrange.
No problem there started the print, all going well till about 85% printed then the extruder stopped moving, no the first time I have had this happen with S3D.
Stopped the print by the printer control panel and decided to give up for the night.
Tonight have tried to print something else and no matter what object I load for printing all it does is start to print the previous nights failed attempt?
Rebooted the PC, Reset the printer, tried all sorts moving items around on print bed layout, rotated and still the same result. Last nights failed print!
I know it is not a problem with the printer as I still have the ReplicatorG software that came with the printer installed and when I use that it works fine!
Can load and print whatever I want, but restart with S3D and it goes back to trying to print the failed print?
This is driving me NUTS!!! Anybody got a clue ..... idea ..... hint ..... tip ...... Yep I'm desperate ...... How to fix this?
