mitchfx
Raise3D N1/N2 support?
Any plans to add configuration presets for the new printers from Raise3D? I believe they are marlin based so I hopefully doing my own settings won't be too difficult once my N2 plus arrives next month.
http://www.raise3d.com
Re: Raise3D N1/N2 support?
It should already be compatible, so you can use the configuration assistant wizard to set it up. It will guide you through the process.
makerjason
Can I get a confirmation if simplify3d does support the N2 printers?
I checked out the supported Pinter's page, and it's not listed.
I'd like to order the unit, but I dont want to learn a new slicer.
You are welcome to email the S3D support staff if you want an answer from them (contact form here: https://www.simplify3d.com/contact-us/).
But again, it uses the Marlin firmware, so it should be compatible. They most definitely already fully support Marlin printers (as I have several printers running the same firmware and they all work great)
