dougirwin212
Fabrikator Mini 1.5
I saw someone who has used one with a Mac.
I got the bright idea to try one of these to keep at work and print small PLA parts on, they received pretty good reviews.
My Simplify software sees the printer and I can manually heat up the extruder.
But my build area show's my Flashforge Creator Pro and I'm concerned about trying to print any thing.
Does anyone have a factory file or process that they would be willing to share.
Any suggestions on how to get this work safely with Smiplify 3D would be greatly appreciated.
Doug Irwin
McKinney, Texas
Re: Fabrikator Mini 1.5
I would go to Help > Configuration Assistant, select Other at the bottom, and then answer the questions that it asks. That will create a customized profile for your machine instead of using the FFCP one that it sounds like you have loaded.
The Fabrikator Mini is already compatible with the software, so it will work once you setup the correct profile using the config assistant
