; filename = simplify3d.gcode
; machine = daVinciAW10do this work with windows?UberBen wrote:After much searching and tweaking I finally got Simplify3d gcode into XYZWare and printed!
I have been printing with with Pro that last few days using this program I found on github: https://github.com/alexander-pick/Simpl ... _converter
It tweaks the gcode generated with Simplify3d and strips the headers to work with XYZWare. I used the default Da Vinci 1.0 profile in Simplify3d and loaded the dummy firmware included with the github project, then tweaked it using settings from XYZWare.
I had to tweak the retraction up to 7mm and the flow to 0.95 with PLA but it has been working out great. I have been printing at 45mm/sec.
made this last night: http://www.thingiverse.com/make:203874
The program is Windows only.m4dunlop wrote:do this work with windows?
