Guernes Machining wrote:Thanks S3RIOUS74, once I got into work yesterday I started over and fresh with everything and used the profile you first put up. Its on the slow side but I am up at 100% for the extrusion multiplier. So I have no idea what I had going on. Once my current part gets done running I will try this new profile. If it works for 910 nylon too that will be great because we are looking at starting to run that for some of our stuff as well.
I sure hope Airwolf works on getting support for the Axiom on s3d like they do for cura.
If you haven't already seen it then I suggest using the provided FFF profile they have created on their dropbox share for AXIOM:
https://www.dropbox.com/sh/1pqphvc6fhzu ... IFY3D?dl=0
I have been printing with this profile (ABS so far) and have had no issues - in fact, I returned Simplify3D then came back once I saw that profile come up.
Only thing I have changed from it is turning off raft support which is on by default.
