I have installed 2.01 and everything seems to be going ok except that the bed leveling wizard is playing up. When you click begin leveling it zeros on the end stops then goes to the corner and touches the first point correctly , but when you push next it goes up and moves to the next x-y coordinate but then doesn't bring the bed up to test it. Hitting next again does the same thing, moves the x-y coordinate but doesn't move the z. I am using a Makergear M2 (purchased around the middle of the year). Running it on Vista 64x (horrid I know) the previous version works fine 1.1.5. I tried quitting and restarting, disconnect, reconnect with no change. Do i need a firmware upgrade or anything like that? Will have a bit more of a fiddle when this print finish and also try it on my mac. Any pointers would be great though?
Cheers
Jimmy
